stwoadis
#1 Posted : Wednesday, November 24, 2010 8:40:33 AM(UTC)
stwoadis
Temp won't go above 25 and freezing food
stwoadis
#2 Posted : Wednesday, November 24, 2010 8:42:50 AM(UTC)
stwoadis
Water in door will not work but ice maker does. Refrigerator temp will not go above 25. Side by side ge
applianceman
#3 Posted : Wednesday, November 24, 2010 9:49:05 AM(UTC)
applianceman
There is a damper in the fresh food section that will often break when this happens cold air will be free to rush in all day. You will have to remove the air duct and look down inside the air duct to see if the flap on the damper is broken or not. This can also be caused by a faulty thermistor. This page will help GE Refrigerator Freezing Food In Fresh Food Section
Once you get this repaired you will have to thaw out the water line behind the bottom bins. They are most likely frozen due to your current problem. That will put the dispenser back to work.
Help - fresh food freezing up! (Refrigerator & Freezer Repair)
by Robd0728 1/12/2015 7:33:15 AM(UTC)
Food freezing in refrigerator (Refrigerator & Freezer Repair)
by Elaine J 9/12/2013 7:10:30 AM(UTC)
Food freezing in fresh food side.............. (Refrigerator & Freezer Repair)
by rkiburis1 9/24/2012 6:41:16 AM(UTC)
Fresh food freezing, temp display shows high temp (Refrigerator & Freezer Repair)
by kartracer 7/23/2012 9:10:00 AM(UTC)
fresh food freezing (Refrigerator & Freezer Repair)
by pterry 3/1/2012 4:52:48 AM(UTC)
food freezing in crisper drawer (Refrigerator & Freezer Repair)
by stockm 7/31/2011 4:31:26 PM(UTC)
Food freezing in main compartment and top produce drawer (Refrigerator & Freezer Repair)
by jrhtools 7/1/2011 12:39:35 PM(UTC)
by wapiwulo 1/7/2011 3:07:39 PM(UTC)
Food Freezing (Refrigerator & Freezer Repair)
by ZMANIA 9/22/2010 6:03:19 AM(UTC)
Food Freezing in fridge section (Refrigerator & Freezer Repair)
by aplprobs 10/26/2009 11:16:27 AM(UTC)
GE Arctica Food freezing on shelves by air tower (Refrigerator & Freezer Repair)
by Arctica28 5/26/2009 7:27:07 PM(UTC)
food freezing in refridgerator (Refrigerator & Freezer Repair)
by vabug72 4/3/2008 11:13:48 AM(UTC)
