jrhtools
#1 Posted : Friday, July 1, 2011 12:39:35 PM(UTC)
jrhtools
Hello, I have aproblem with food freezing in the main compartment and top produce drawer in our Maytag MZD2768GE.
richappy
#2 Posted : Friday, July 1, 2011 2:51:14 PM(UTC)
richappy
Measure the freezer temperature and post. Should be below zero if fridg running all the time. Critical to get a reading after the temperature has stabilized.
jrhtools
#3 Posted : Friday, July 1, 2011 8:03:05 PM(UTC)
jrhtools
Hello, the temperature in the freezer compartment shows to be 10 degrees below zero. What should I check next?
Thanks,
richappy
#4 Posted : Saturday, July 2, 2011 1:38:28 AM(UTC)
richappy
You probably have a bad cold control AP4070269
jrhtools
#5 Posted : Saturday, July 2, 2011 6:00:15 AM(UTC)
jrhtools
Where would I find the cold control and how to check it?
richappy
#6 Posted : Saturday, July 2, 2011 7:08:05 AM(UTC)
richappy
Behind the control panel where the temperature control knob is. Make sure to route the new sensing wire exactly where the old one was. Symptoms show a bad control. Try spraying with a non-residue contact cleaner available at Radio Shack, might un-stick it.
jrhtools
#7 Posted : Thursday, July 21, 2011 7:21:24 AM(UTC)
jrhtools
Hello, I changed temperature control which fixed freezing problem in main refrigerator compartment.The top produce drawer will change from a setting above freezing to 25 degrees and freezes food. Any suggestions as to what I need to replace to fix this problem?
John
