Arctica28
#1 Posted : Tuesday, May 26, 2009 7:27:07 PM(UTC)
Arctica28
Hi. I have a GE PROFILE ARCTICA. I recently put a pack of parsley on my shelves in a bag, and I have noticed that some of the leaves have frozen and the same thing with radishes, the temperature display is reading the proper temp and recently ge has replaced the damper in the fridge but the same thing is happening. I dont know if it's because the parsley was right in front of the vent on the air tower or what but all other produce and stuff and it's fine. Can someone help. thanks:mad:
woodchuckie
#2 Posted : Wednesday, May 27, 2009 4:38:56 AM(UTC)
woodchuckie
I would make sure the damper is opening and closing as the temp is adjusted colder and warmer. Perhaps you could check the temp at that spot in the fridge and another spot.
Arctica28
#3 Posted : Wednesday, May 27, 2009 9:15:08 AM(UTC)
Arctica28
hi again. see thts the problem. the greens i had only froze in the area where the vents from the tower are, not in any of the drawers or even further away from the vents. Do you think it sounds like a malfunction. I checked the damper and it's opening and closing. You think the temp is just too cold and and just really close to the vent and that's why it's doing that?? Thanks/
woodchuckie
#4 Posted : Wednesday, May 27, 2009 10:48:10 AM(UTC)
woodchuckie
Yes, I think I would try it just a little warmer on the fridge control.
Arctica28
#5 Posted : Wednesday, May 27, 2009 11:00:47 AM(UTC)
Arctica28
Hi thanks for your help. Just to make sure, you mean you think the fridge is ok just to adjust the control a little warmer?? Thanks
woodchuckie
#6 Posted : Wednesday, May 27, 2009 11:07:48 AM(UTC)
woodchuckie
Yes, that's what I would try.
