cuttem
#1 Posted : Tuesday, November 9, 2010 2:26:11 PM(UTC)
cuttem
Oven w'ont heat to temp. It will heat to aprox 250 degrees when set to 450. Broiler works fine. Is this a sensor problem or something else?
Thank you,
Jim
Joe / APP Team
#2 Posted : Tuesday, November 9, 2010 2:38:37 PM(UTC)
Joe / APP Team
Thank you,
Jim
Jim,
Yes , it could be a bad sensor,
Do you have a multimeter to test the sensor resistance ?
Were it me , I would start at the bake element itself.
I would check for, cracked or melted area(s) on the element coating.
I would also remove the element mounts and check for loose or melted connections, or wires, you may even want to test for 240 volts on the element terminals, in a bake cycle, then test the sensor circuit and control if all checks OK.
Good Luck,
:cool: :cool: :cool:
GE oven wont heat to temp (Oven Repair (including Ranges and Cooktops))
by cuttem 11/9/2010 2:25:04 PM(UTC)
