gentleben
#1 Posted : Thursday, July 19, 2007 5:09:31 AM(UTC)
gentleben
Please give me the location of water valve part # AP3160649 (4389177)and the procedure to replace same
gentle ben
Matt / APP Team
#2 Posted : Thursday, July 19, 2007 10:04:01 AM(UTC)
Matt / APP Team
Rank: Administration
Groups: Administrators
The water valve is located in the rear of the fridge, just follow the water line from the wall. Here is the correct water valve for the model number you provided: Part Details - WHIRLPOOL Water inlet valve kit, part number: AP3160649
Changing it is pretty basic, it will be held in by 1 or 2 screws. So first turn off the water and power!! Disconnect the water lines and wire connectors, make sure you keep track of what goes where! Installing is just reverse of removal. The new valve has the new quick connectors, all you do is insert the water lines until they bottom out. Make sure when you cut the lines that they get a clean, straight cut. Any ruff edges or angled cuts may damage the O-rings as you push the lines into the valve. Once reinstalled check for leaks.
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Water inlet valves burning out (Dishwasher Repair)
by Tydinelle 3/3/2024 4:06:06 PM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Whirlpool Water Inlet Valve Repair for Leak (Refrigerator & Freezer Repair)
by ForumUser1 12/23/2023 12:57:44 PM(UTC)
Water Inlet Valve WR57X10033 / AP3189335 for General Electric DTL18ICSRRBS (Refrigerator & Freezer Repair)
by breckrider 1/18/2023 7:43:17 PM(UTC)
Replaced water inlet valve, still no ice or water (Refrigerator & Freezer Repair)
by Guest 7/3/2021 3:14:08 PM(UTC)
dishwasher not filling with water...already changed water inlet valve (Dishwasher Repair)
by jbonez 5/25/2021 5:32:22 PM(UTC)
Leaky new water inlet valve on whirlpool gold refrigerator (Refrigerator & Freezer Repair)
by Guest 4/4/2021 5:35:03 PM(UTC)
Water Inlet Valve for Whirlpool WRF560SEYW05 (Refrigerator & Freezer Repair)
by nycgene 7/30/2020 10:50:55 AM(UTC)
Noise after water inlet valve replacement (Refrigerator & Freezer Repair)
by Kristsivia 11/3/2019 4:29:36 PM(UTC)
GE washer replace WH13X10057 water inlet valve (Washer Repair)
by Cmath 3/9/2017 9:23:21 AM(UTC)
Water inlet valve (Washer Repair)
by dcbradt 3/8/2017 4:02:37 AM(UTC)
Water inlet valve leaking (Washer Repair)
by Jimh64 1/29/2016 7:31:50 AM(UTC)
Hot to replace water inlet valve on GE washer dryer combo WSM2700HCWWW? (Washer Repair)
by AbbyBrickman 1/4/2016 8:36:24 PM(UTC)
