jogrodz
#1 Posted : Monday, April 2, 2018 6:36:28 AM(UTC)
jogrodz
GE clothes washer will not spin, oily substance under motor area.
Joe / APP Team
#2 Posted : Tuesday, April 3, 2018 7:08:22 AM(UTC)
Joe / APP Team
jogrodz, Is the lid latching ? and the tub moves freely if you turn it by hand ? You may want to access the control console and retrieve the Tech Data Sheet and review the error codes logged by the memory chip on the control board. It'll give you a good place to start the diagnosis and repair. The oily substance, could be residual grease or oil from the production of the washer, but you will want to remove the pulley, belt and motor to check that the Gearcase hasn't had a seal failure and leaking oil into the motor and clutch assembly causing the Gearcase to malfunction and not spin.
jogrodz
#3 Posted : Friday, April 6, 2018 6:06:27 AM(UTC)
jogrodz
Lid latches, tub can be turned by hand.
Tub starts to spin, makes a few thumping noises then stops.
Joe / APP Team
#4 Posted : Friday, April 6, 2018 6:46:00 AM(UTC)
Joe / APP Team
Jogrodz, The noise and no spin situation is most likely due to a problem in the mode shifter/clutch assembly, as long as the belt and pulley are OK. Use the tech data sheet to review the error codes, check the belt, mode shifter and clutch. If all's OK, you'll need to consider a new control board, there could be a "glitch" in the board circuitry that's causing the washer to stop spinning because of a "false" off balanced load.
Whirlpool duet clothes washer (Washer Repair)
by DThiessen 9/28/2022 10:08:52 AM(UTC)
clothes washer don't work, troubleshooting manual wtw5500xw0 cabrio (Washer Repair)
by paulmars 4/2/2022 10:43:24 AM(UTC)
Kitchenaid clothes washer (Washer Repair)
by 76 Terra 1/24/2022 10:05:31 AM(UTC)
clothes washer only leaks when filling (Washer Repair)
by elijahfischer 8/22/2013 7:06:46 AM(UTC)
Maytag clothes washer (Washer Repair)
by fnolen 7/21/2013 3:04:54 PM(UTC)
Kitchenaid clothes washer won't spin without a push (Washer Repair)
by dlunde 5/29/2013 5:23:00 PM(UTC)
GE Clothes washer won't advance to wash cycle (Washer Repair)
by Zog 2/11/2013 4:33:01 PM(UTC)
Clothes Washer (Washer Repair)
by louis Dionise 12/14/2012 10:40:32 AM(UTC)
Clothes Washer Lint Issue (Washer Repair)
by kenmoregator 11/30/2012 3:01:10 AM(UTC)
by duffybpp 8/30/2012 3:28:44 AM(UTC)
Whirlpool Clothes Washer (Washer Repair)
by DirtyClothes1 7/7/2012 4:01:42 PM(UTC)
lint clothes washer (Washer Repair)
by paulmars 3/16/2012 4:21:12 PM(UTC)
Whirlpool Clothes Washer time won't advance (Washer Repair)
by djaco4749 3/9/2012 8:11:44 AM(UTC)
Clothes Washer won't spin clothes dry (Washer Repair)
by JCHD 1/26/2012 7:09:42 AM(UTC)
by cktab 11/22/2011 6:39:43 PM(UTC)
