fivermillions
#1 Posted : Sunday, February 21, 2016 5:23:23 AM(UTC)
fivermillions
Maytag Centennial gets out of balance banging the tub against the walls, especially with small loads. Also, clothes get wrapped tight around the agitator - especially towels, jeans.
Other posts recommend replacing the suspension for the out of balance (rods and springs), but curious if the out of balance would also cause clothes to get wrapped around the agitator.
follow up...
watched the wash cycle without clothes, detergent
washer completely filled up with water - should it do this without clothes.
the agitator top and bottom section is turning clock wise - creating a whirlpool
The tub is slowly turning clockwise in small steps - I think it wants to turn counter clockwise
fivermillions
#2 Posted : Monday, February 22, 2016 4:57:08 PM(UTC)
fivermillions
Follow up, washer seems to work with a washer full of clothes
fivermillions
#3 Posted : Wednesday, February 24, 2016 4:47:22 PM(UTC)
fivermillions
Finally figured it out, for light loads the agitator top section is not supposed to turn, however, the water should only fill up partially. The bottom section of the agitator does the work (top half of agitator is above the water).
In my case, the water was filling to the full level, then washing with the agitator top and bottom locked - which then tended to wrap clothes around the agitator and create a large in balance.
The air line and nipple at the tub were clear, therefore my control panel is bad.
Maytag centennial washer- motor won’t spin (Washer Repair)
by Guest 3/30/2024 1:59:24 PM(UTC)
Maytag Centennial Washer MVWC415EW0 Agitation issue (Washer Repair)
by Guest 5/27/2021 9:58:45 PM(UTC)
maytag centennial washer (Washer Repair)
by arodriguez01 2/6/2018 8:29:06 AM(UTC)
maytag centennial washer low fill (Washer Repair)
by redjada 9/3/2017 9:01:47 AM(UTC)
Maytag Centennial Washer doesn't Agitate (Washer Repair)
by hosehead78 4/16/2017 5:46:30 PM(UTC)
Maytag Centennial Washer Stops Mid-Cycle (Washer Repair)
by washer2017 3/16/2017 5:58:01 AM(UTC)
Maytag centennial washer drum sits too low (Washer Repair)
by jansmeall 12/8/2016 11:59:20 AM(UTC)
maytag centennial washer wont goo into spin cycle (Washer Repair)
by shennondw 8/9/2016 6:20:41 PM(UTC)
Maytag Centennial washer stops after filling (Washer Repair)
by dfrancey 5/5/2015 7:41:28 AM(UTC)
Maytag Centennial washer will not start (Washer Repair)
by TurnpikeJ09 3/8/2015 7:44:44 PM(UTC)
Maytag Centennial Washer (Washer Repair)
by maytagQuestion 3/2/2015 1:11:52 PM(UTC)
by Scotty1231 10/5/2014 7:45:25 AM(UTC)
Maytag Centennial Washer Transmission??? (Washer Repair)
by Fixit-teer 4/13/2014 6:58:06 PM(UTC)
by ShadeTree231 3/23/2014 5:02:51 PM(UTC)
maytag centennial washer, loud spinning sounds (Washer Repair)
by korean1 11/16/2013 6:53:18 PM(UTC)
