I get these instructions to take out the old auger motor.
Instructions for part 2252130
[FONT="Helvetica Neue",Arial,sans-serif]To remove the motor: a) Open the freezer door. b) Remove the ice container from the freezer door. c) Remove the two screws from the motor housing cover, located under the bottom of the inner door panel, (You may need to lay in the floor and look upward inside the door to see where they are)[/FONT]
[FONT="Helvetica Neue",Arial,sans-serif][/FONT]
[FONT="Helvetica Neue",Arial,sans-serif]I can't figure out if I have a different version but I can't see how to replace this can I send someone pictures on what to do or is there a video that shows what to do[/FONT]
