Azurescens
#1 Posted : Tuesday, February 5, 2013 4:21:41 PM(UTC)
Azurescens
The water & ice dispenser isn't working at all. No water/ice comes out, no lights, the buttons don't do anything, nothing at all. It started with the line to the water dispenser coming loose from the spout. A friend decided he would fix it, and during the course of this attempt, one of the circuit boards was dropped in a puddle of water. When it was reassembled, it had ceased to function. I'm assuming the board is now dead and needs to be replaced, but it's been a while since this happened and I can't remember if it was the power board or the switch board.
Is there a way to test them to see which is bad, or does the fact that it does nothing at all indicate which it would be? Or could it just be a coincidence, and it's something completely different?
And, on a related note, what's the proper type of adhesive to use to glue the water line back into the spout?
#2 Posted : Wednesday, February 6, 2013 3:17:24 PM(UTC)
If there are no lights in the dispenser then the power board has to be replaced.
I did not get clear where the water line was loose. Can you refer to the diagrams bellow please?
- The power board Part number: 241708102
Azurescens
#3 Posted : Wednesday, February 6, 2013 6:44:52 PM(UTC)
Azurescens
Thanks for the info. I'll purchase the power board, then.
The water line came loose from the little external spout that the water actually comes out of. I think it would be the hollow conical part on the Module-Dispenser. It looks like it was just glued in place, but the adhesive broke. I can post pictures of the actual unit if need be.
Thanks again.
#4 Posted : Thursday, February 7, 2013 1:23:25 PM(UTC)
Originally Posted by: Azurescens Go to Quoted Post
...I can post pictures of the actual unit if need be...
Yes please. It might help.
Water/Ice dispenser not working... (Refrigerator & Freezer Repair)
by CartmanMTB 1/31/2011 2:05:25 PM(UTC)
Water/Ice Dispenser not working after the refrigerator stopped. (Refrigerator & Freezer Repair)
by kanhs 6/1/2010 9:19:35 AM(UTC)
GE mainboard replaced, now water/ice dispenser not working. (Refrigerator & Freezer Repair)
by TravisR 4/2/2010 9:27:59 PM(UTC)
water/ice dispenser not working (Refrigerator & Freezer Repair)
by mollyt 2/22/2009 3:19:27 PM(UTC)
