crosby1
#1 Posted : Friday, November 22, 2013 7:07:48 AM(UTC)
crosby1
I have a GE GSH25SGPASS side by side refrigerator. In the past few days, it hasn't stopped running. Even if I turn the thermostat all the way to the warmest setting it doesn't shut off. Both sides seem to be cold; it just won't stop running. I've looked at the damper mechanism between the freezer and fridge and it seems to open and close normally.
What can I check/repair/replace to fix the issue?
Thanks very much!
Appliance Ninja
#2 Posted : Friday, November 22, 2013 7:14:23 AM(UTC)
Appliance Ninja
Do you have a thermometer to actually measure the temperature in the freezer? Can you see any frost on the back wall inside the freezer?
crosby1
#3 Posted : Friday, November 22, 2013 7:24:58 AM(UTC)
crosby1
hi, thanks. the freezer temp is about 5 degrees F. there is a thin layer of frost on the back wall.
Appliance Ninja
#4 Posted : Friday, November 22, 2013 7:46:36 AM(UTC)
Appliance Ninja
Are you able to remove that rear panel and look at the coil behind it for frost build up? Do you have a meter to test continuity with?
crosby1
#5 Posted : Friday, November 22, 2013 7:59:41 AM(UTC)
crosby1
Yes, the coils are completely frosted over from top to bottom.
I don't have a meter to check continuity (I'm not sure what that is as it applies to refrigerators).
Thanks again.
Appliance Ninja
#6 Posted : Friday, November 22, 2013 8:05:28 AM(UTC)
Appliance Ninja
Okay, so that is why the long run times. You will need to totally thaw the coils out to restore operation. The most common cause of that issue is a faulty heater. Once the frost is clear, you will see a glass tube at the bottom of the coil. Does that glass look dark or burnt at any section?
crosby1
#7 Posted : Friday, November 22, 2013 8:21:07 AM(UTC)
crosby1
hmmm, actually the glass tube does look like it's dark and burnt at both ends. it's also very cloudy and sort of a greenish color in the middle.
Appliance Ninja
#8 Posted : Friday, November 22, 2013 8:25:20 AM(UTC)
Appliance Ninja
Thaw those coils and order the part below. You will have about 5 days until it freezes up again. That should get you back up and running well!
GE WR51X10055 Heater and Bracket Assembly - AppliancePartsPros.com
crosby1
#9 Posted : Friday, November 22, 2013 8:33:06 AM(UTC)
crosby1
You are awesome!!! Thanks very very much. You've saved me what I'm sure was gonna be a ton of money for a service call!!
VERY much appreciated!!
Appliance Ninja
#10 Posted : Friday, November 22, 2013 8:42:30 AM(UTC)
Appliance Ninja
You are very welcome. Have a great weekend! Thank you!
