blackbeard1298
#1 Posted : Thursday, April 30, 2009 4:50:12 PM(UTC)
blackbeard1298
My G.E. microwave stopped heating last week and decided to check door switches, transformer, thermal protectors, hv capacitor, and hv diode. everything checked out except for the diode. It showed infinite readings when checked both ways, which should mean that the diode is open. So I ordered a new diode from you guys, part no. WB27X10597 and decided to check it for resistance before replacing it. And the new diode shows infinite readings when checked both ways. Do you think that the new diode is open as well?
Thanks,
John
applianceman
#2 Posted : Thursday, April 30, 2009 6:13:27 PM(UTC)
applianceman
Diodes on microwaves are open one-way and a very high resistance the other. So if your meter isn’t set high enough it will read as if it were open. Some ohmmeters do not have a high enough scale to check diodes. I have owned a few ohmmeters would not check microwave diodes. But it’s ok you need to replace it anyways along with you magnetron tube. Microwave Repair Guide
Microwave does not Heat Food (Microwave Repair)
by newatappliancerepair 11/10/2016 10:53:37 AM(UTC)
Microwave does not heat (Microwave Repair)
by flynkites 2/4/2013 6:28:06 AM(UTC)
Microwave does not heat...buzzing sound (Microwave Repair)
by bnhmiles 3/15/2012 3:33:46 PM(UTC)
Whirlpool Microwave Does Not Heat (Microwave Repair)
by FixItManTim 7/17/2011 9:06:24 PM(UTC)
microwave does not heat (Microwave Repair)
by suzzan 4/30/2011 2:42:48 PM(UTC)
GE Profile Microwave does not heat any more (Microwave Repair)
by dealmaster 10/13/2010 3:21:06 PM(UTC)
my microwave does not heat (Microwave Repair)
by videomandw 8/16/2010 6:37:53 AM(UTC)
ge microwave does not heat, everything else works (Microwave Repair)
by shaunshaw 4/7/2010 10:36:03 AM(UTC)
by Alex1977 11/15/2009 10:23:07 AM(UTC)
Kenmore microwave does not heat (Microwave Repair)
by srikki9 9/7/2009 11:15:49 AM(UTC)
Microwave does not heat up. (Microwave Repair)
by Aliens1 5/27/2009 9:32:29 PM(UTC)
microwave does not heat, smells like its burning and buzzes (Microwave Repair)
by doogie48084 5/26/2009 10:58:40 AM(UTC)
Jenn Air Microwave does not heat (Microwave Repair)
by SpacemonkeyR 4/23/2009 5:52:19 PM(UTC)
by Kerryi 3/19/2008 1:46:51 PM(UTC)
by Bob Shuler 10/29/2007 7:55:21 AM(UTC)
