I have replaced my control board in my double oven because the touch panel was not working (thunder storm did it again).:( After installation and powering up the unit it is asking to set up the unit. I do not have a clue of what to put in. Is there a service manual for the unit that tells me how to do it? If so I would like to purchase it.
when replacing the control board, the board has to be told what oven it is in.
it needs to know if it is a g.e. profile, or a g.e. monogram.
here are instructions
power oven off.
power oven back on.
within 5 mins of powering up, press 0803
press factory 1 on display
press change until it displays proper name
press accept, to confirm
press exit.
you should be able to say "presto"
scott
