AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
how do I replace water line in freezer door of whirlpool side by side
Do you mean this cannot be repaired? The part is no longer available? Please expand Thank-you
This part even does not have a part number. Looks like it was not serviceable by design.
Whirlpool gold model #GS6NVEXSL01 27 side by side
Originally Posted by: jacsac ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Whirlpool gold model #GS6NVEXSL01 27 side by side Not sure if you mean me et25dqrbw00 Whirlpool but the inside of the door is filled with a hard foam. I cut out the foam near where the water tube went in and found the 1/4" water tube inside a slightly larger plastic tube which I carefully cut into and pulled out a section of the 1/4" water tube an spliced in a piece of 1/4" water tubing using the connectors they sell here. It worked fine . I did not try to replace the small amount of foam I hacked out -seems to have no effect on temperature of fridge. There is a metal coil that the water tube has to go thru as it passes from the door to the fridge to keep the water tube from getting cut make sure that metal coil is secure inside the fridge door and passes thru the hole in the bottom of the door(duct tape).
I have this same problem with our LG fridge. The hose is broken near the bottom under the freezer door. How do I repair it?
I have a water line that is leaking inside the door of a GE fridge with this model number: PSF26NGTDWW I took the face plate and electric components out kind of like in this video: https://www.youtube.com/watch?v=lnEV4ZHC_W4 But it wasn't abundantly clear where the water line hose was inside there. Can you please let me know if this is DIY able. I am VERY handy and have done many fridge repairs in the past.
