blonda1972
#1 Posted : Monday, April 6, 2009 2:38:22 AM(UTC)
blonda1972
I have a 5 year old maytag gas oven model MGR5755QDW that will not heat up on the bake mode. The broiler and clean mode both seem to work fine.
#2 Posted : Monday, April 6, 2009 4:46:33 PM(UTC)
Most likely the problem is a bad Bake igniter. You have to remove the oven floor and the flame spreader to access the part.
- The part number for the igniter is AP4012072
reallynotveryhandy
#3 Posted : Thursday, April 16, 2009 12:31:56 PM(UTC)
reallynotveryhandy
I had the same problem with the same model: MGR5755QDW.
I luckily found this thread and ordered the bake igniter suggested by Gene. Ordering was easy and the part came quickly ($55 with shipping). Great experience. I installed the part with the instructions it came with and page 30 of the service manual I found here: http://www.servicematters.com/m...ibrary/docs/16022498.pdf
My notes:
- Be sure to unplug the oven from the electrical outlet and disconnect the gas.
- The oven door comes off easily once you find the little latch on each hinge that rotates forward. I used a screwdriver to pry the latch forwad.
- Study how the old igniter is set up before removing it. That was my best guide to how the new one should be installed.
- The bracket and wire connection options were a bit confusing (at least to me). The bracket the new igniter came preinstalled was right for me, and I ende up cutting off the weird (and different) connectors on both ends (the igniter end and the oven end) and connecting the wires with the included ceramic wire caps.
I never fixed anything like this before, but I just heated my oven to 350. Awesome.
It seems possible that my old igniter was perfectly OK and that my problem was just a loose connection - especially since I had moved this oven recently. But I didn't want to mess around once I got in there to fix it, so I was happy to just buy and install the new part.
#4 Posted : Thursday, April 16, 2009 6:38:50 PM(UTC)
Thank you for sharing your experience. Good job!
Upper Maytag oven won't heat (Oven Repair (including Ranges and Cooktops))
by tfuertes 2/28/2012 4:28:57 PM(UTC)
Maytag Oven Won't heat up (Oven Repair (including Ranges and Cooktops))
by Petezr 1/25/2012 6:27:38 PM(UTC)
by easye 6/22/2011 7:42:28 PM(UTC)
Maytag oven won't heat up (Oven Repair (including Ranges and Cooktops))
by steelerfan349 10/22/2010 2:42:24 AM(UTC)
Maytag Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by Miken47 6/5/2010 8:50:29 AM(UTC)
Maytag Oven Won't Heat After Self Clean Cycle (Oven Repair (including Ranges and Cooktops))
by blindab 12/1/2009 6:57:24 AM(UTC)
