Grump
#1 Posted : Sunday, January 13, 2013 7:15:30 AM(UTC)
Grump
After the drying cycle, the buzzer goes off normally. When opening the door the buzzer stops, but then resumes when the door is closed. Also if you open the door during the drying cycle, the heat and drum rotation will stop when you open the door, but will restart without pushing the start button when you close the door. Any suggestions on what the problem may be? Thanks...
#2 Posted : Monday, January 14, 2013 12:12:54 AM(UTC)
A model number may help others help you.
Find your model number - AppliancePartsPros.com
Grump
#3 Posted : Monday, January 14, 2013 5:58:51 AM(UTC)
Grump
Sorry. Part number: 96589210 Serial number: ME4521363
#4 Posted : Tuesday, January 15, 2013 12:33:20 AM(UTC)
You are still missing part of the model number.
Kenmore numbers are usually 3 digits, a period and then another 8 digits.
The first 3 digits actually tells you who made the unit as Kenmore does not make the machines.
Grump
#5 Posted : Tuesday, January 15, 2013 6:15:27 AM(UTC)
Grump
Here is what the sticker inside the door says:
MODEL/STOCK NO.
96589210 65892
No other numbers except the serial no.
#6 Posted : Wednesday, January 16, 2013 3:33:44 AM(UTC)
Searching for "80 Series" brings up a 110 prefix so I think the model is a 110.96589210.
Parts for Kenmore Dryer 11096589210 - AppliancePartsPros.com
Unfortunately I cannot find a wiring diagram for this unit so have to do some guessing.
You may have two problems in the unit.
First unplug the unit and one wire at the push to start switch.
Measure the switch. It should be infinite ohms and then drop to 0 ohms when pushed.
The motor has two centrifugal switches on it. One is for the heating coil. The other is for the start winding disconnect and a start switch by-pass. They are activated when the motor gets close to operating speed.
When you push the start switch the motor runs the centrifugal switches close. Now one of them is for an alternate (parallel) circuit for the start switch. This lets you release the start switch and the motor keeps running.
Since your motor starts running without pushing the start switch odds are that it is shorted.
Timer problem? (Washer Repair)
by johnvbf 1/6/2017 11:44:13 AM(UTC)
Whirlpool EHT 201 OLD!!! Defrost Timer Problem? (Refrigerator & Freezer Repair)
by dsoelter 9/15/2014 3:42:07 PM(UTC)
Possible timer problem? (Dryer Repair)
by vorsk 2/26/2014 6:31:24 AM(UTC)
defrost timer problem? (Refrigerator & Freezer Repair)
by BSTrue 8/12/2013 3:12:50 PM(UTC)
Is this a washer timer problem? (Washer Repair)
by hanketron 4/18/2013 12:00:25 PM(UTC)
Kenmore 600 Series Timer Problem? (Washer Repair)
by fedup352 5/3/2012 10:56:38 AM(UTC)
Maytag washer, timer problem? (Washer Repair)
by Rene' 9/1/2011 5:48:01 AM(UTC)
by butlermom9 2/21/2011 12:19:36 PM(UTC)
Kenmore Electric Dryer - Timer Problem?? (Dryer Repair)
by gus1 2/21/2011 8:55:50 AM(UTC)
Maytag timer problem? (Washer Repair)
by Aaron2010 6/24/2010 9:21:34 AM(UTC)
Timer problem???? (Washer Repair)
by sacto 10/12/2009 7:44:26 AM(UTC)
by tyount 8/26/2009 3:48:20 PM(UTC)
Timer Problem? (Dryer Repair)
by Amamaman 8/25/2009 4:29:06 PM(UTC)
by dpeter33 6/22/2009 6:21:43 PM(UTC)
Timer problem?? (Washer Repair)
by eamiller 5/26/2008 1:49:20 PM(UTC)
