ellmer
#1 Posted : Tuesday, September 25, 2012 1:25:15 PM(UTC)
ellmer
Washer spins violently like it is out of balance. I have replaced the drive block, clutch, suspension springs, agitator repair kit and transmission. Symptoms still the same. Any ideas?
richappy
#2 Posted : Tuesday, September 25, 2012 2:06:22 PM(UTC)
richappy
The skate plate under the tub might be out of place, just look at both sides to see if they are not symetric. Also, lift the skate plate and check for missing half round, brown, plastic slides.
ellmer
#3 Posted : Wednesday, September 26, 2012 5:21:46 PM(UTC)
ellmer
Thank you for your prompt and accurate diagnosis of my KitchenAid Washer. Once the skate plate was properly positioned it functions smoothly.:)
richappy
#4 Posted : Thursday, September 27, 2012 12:11:41 AM(UTC)
richappy
Thanks for the response. I have fixed a lot of these washers and find it's best to tip the washer back for service, but never lay it down all the way as the skate plate may go out of position once uprighted.
kitchenaid washer kaws800gq1 (Washer Repair)
by maagk 7/10/2020 5:47:30 AM(UTC)
Kitchenaid washer does everything but spin (Washer Repair)
by donohu40 10/27/2016 7:34:05 AM(UTC)
KitchenAid washer stopped spinning (Washer Repair)
by Punisher Bass 7/10/2015 4:30:16 PM(UTC)
need helpplease with trouble shooting kitchenaid washer (Washer Repair)
by lmormsby 5/14/2014 2:55:31 PM(UTC)
Older kitchenaid washer that worked fine and then? (Washer Repair)
by yepyepdude 1/29/2014 7:30:32 AM(UTC)
Kitchenaid washer pulling my hair out! (Washer Repair)
by DANShandy 7/29/2013 4:28:39 AM(UTC)
KitchenAid Washer Weird Issue -Electrical? (Washer Repair)
by zee652 4/2/2013 8:17:05 AM(UTC)
KitchenAid Washer won't drain or spin (Washer Repair)
by MSUMOM 3/14/2013 7:25:53 PM(UTC)
kitchenaid washer won't spin (Washer Repair)
by rdtjr1968 9/23/2012 2:54:36 PM(UTC)
a Kitchenaid washer (Washer Repair)
by wapanstore 2/20/2012 8:15:00 PM(UTC)
kitchenaid washer throwing fault codes (Washer Repair)
by buldog9 1/18/2012 11:45:18 AM(UTC)
by carrisal 10/13/2011 3:22:01 PM(UTC)
by carrisal 9/30/2011 2:45:01 PM(UTC)
KitchenAid Washer (Washer Repair)
by murielh 5/22/2011 9:25:08 AM(UTC)
Kitchenaid washer with very slow agitation (Washer Repair)
by brewer89 3/17/2011 10:19:40 AM(UTC)
