rdtjr1968
#1 Posted : Sunday, September 23, 2012 2:54:36 PM(UTC)
rdtjr1968
Kitchenaid washer drains fine, but won't spin. Checked the coupler and it's just fine. Removed the cover from the gearcase and restored power to check things out. The spin gear appears to be turning just fine, so put cover back on gearcase but shaft does not turn. Any suggestions?
I was also off a little on the age of the machine. 10-15 years would be more accurate.
#2 Posted : Monday, September 24, 2012 1:48:34 PM(UTC)
What is the complete model number of the washer?
rdtjr1968
#3 Posted : Tuesday, September 25, 2012 3:52:21 PM(UTC)
rdtjr1968
model number KAWS677EQ
#4 Posted : Tuesday, September 25, 2012 4:02:04 PM(UTC)
Would it spin if you will open and close the lid while the washer is draining?
If it did, replace the timer.
- The timer Part number: 3950736
Kitchenaid washer won't spin (Washer Repair)
by Fidsters 10/16/2010 4:40:37 PM(UTC)
Kitchenaid Washer won't spin/agitate (Washer Repair)
by sofasurfer 7/26/2009 7:05:34 PM(UTC)
by graciousaint 5/18/2009 5:38:16 AM(UTC)
KitchenAid Washer Won't Spin (Washer Repair)
by frankla10 1/20/2009 2:35:36 PM(UTC)
Help! Kitchenaid washer won't spin or drain (Washer Repair)
by harleygurl 11/28/2008 3:54:39 PM(UTC)
KitchenAid washer won't spin (Washer Repair)
by Sherry 8/30/2007 5:57:43 AM(UTC)
