Originally Posted by: Gene Jeff,
We are glad to hear we could help you out. If there is anything else we can help you with, drop us a line.
Gene. I sure will Gene, well today the dryer is on and no heat..last night after I turned the coil right side up it was fine I watched the flame with a mirror. Now you can see the ignitor glowing but that's it no flame and the ignitor stays on...any ideas Gene?? thanks Jeff
Jeff,
What is the complete model number of the dryer?
Gene. GE...Model # DVLR223GGWW Gas Dryer Installed 8-2005 Jeff
OOOps DVLR223GG1WW MISSED THE 1 SORRY
Originally Posted by: Gene Thanks again Gene, I will get that part appreciate your time looking into this issue. Jeff
You are welcome Jeff. Keep us posted.
Originally Posted by: Gene You are welcome Jeff. Keep us posted.
Gene. Sure will and Appliance Parts Pros are coming in $12.00 less on the part which is a lot on a $57.00 part from our local supplier and as your site mentions 365 days returns on all parts, which most will not take back electrical gas etc. Jeff
Gene. Hi Gene, I'm back well I didn't even get to order the flame sensor that was going to be tomorrow, and the dyer completely stopped again No heat. No ignitor glow etc. So while at the store I did pick up a multimeter figured it wouldn't hurt to have one around. Plus I could check everything pretty much. Anyway I checked all the thermostats etc high limit ,flame sensor I'm getting continuity on all. So I checked the ignitor and that has no continuity so I am assuming its no good. From everything that I have read. This sound correct...as everything else checked out or am I missing something Gene.? thanks Jeff
Hi Jeff, If the igniter shows no continuity than it is definitely bad and has to be replaced. I'm still suspecting the flame sensor too. - The igniter Part number: WE4X739
