ANDYSUE57
#1 Posted : Monday, March 30, 2009 12:11:49 PM(UTC)
ANDYSUE57
How Do I Replace The Defrost Heater In My Frig
woodchuckie
#2 Posted : Monday, March 30, 2009 2:11:30 PM(UTC)
woodchuckie
remove the evaporator cover to gain access.The back panel in the freezer. Then remove the the 1/4" screw that holds the evaporator at the bottom and moved the evaporator outward to remove the heater element. Then install new heater element from the bottom of the evaporator making sure it is in the center of the evap coils.
I assume you have tested and found the heater bad.
ANDYSUE57
#3 Posted : Tuesday, March 31, 2009 3:07:16 PM(UTC)
ANDYSUE57
I ASSUME IT IS NO GOOD, IT IS BROKEN INTO 2 PIECES, AND THE PICTURE OF THE REPLACEMENT IS IN ONE PIECE. THANK-YOU FOR YOUR ANSWER, :)
Frigidaire side-by-side - ice at bottom of freezer? (Refrigerator & Freezer Repair)
by stupendousyappi 7/22/2021 11:30:28 AM(UTC)
Frigidaire side-by-side w no control display lights (Refrigerator & Freezer Repair)
by Tlai95 1/6/2014 6:36:09 PM(UTC)
Frigidaire side-by-side fridge side leaking under crisper (Refrigerator & Freezer Repair)
by FixingIt 12/29/2013 5:39:29 PM(UTC)
Repair Directions Needed for Frigidaire side-by-side (Refrigerator & Freezer Repair)
by DV19 7/15/2012 9:06:52 AM(UTC)
Frigidaire side-by-side cooling problems (Refrigerator & Freezer Repair)
by ChrisTN 2/9/2012 12:28:37 PM(UTC)
Frigidaire side-by-side --- no ice, no water (Refrigerator & Freezer Repair)
by kosamson 9/16/2009 6:29:49 PM(UTC)
How do I change the water actuator on Frigidaire Side-by-side (Refrigerator & Freezer Repair)
by Tosha1 6/18/2009 5:30:22 AM(UTC)
