ibew716
#1 Posted : Thursday, June 14, 2012 8:15:04 AM(UTC)
ibew716
my microwave won't heat food and the turntable wont spin. Every thing else such as such as the fan, lights,timer and control pad works. Please help!
ibew716
#2 Posted : Saturday, June 16, 2012 9:06:27 AM(UTC)
ibew716
Originally Posted by: letsride2384 Go to Quoted Post
Check your mag tube inside your microwave, however make sure you discharge your capacitor before you do any work inside of it because it holds up to 2000-4000 volts of electricity.
Thanks... I'll try not sure on how to discharge a capacitor though
#3 Posted : Sunday, June 17, 2012 3:56:02 AM(UTC)
In my opinion microwaves are best left to the pros unless you have some electrical or electronics training experience.
You are messing with high voltage, in other words it can kill you.
Or at the very least give you a nasty voltage burn.
Also without a wiring diagram you will just be taking shots in the dark.
It is a GE so unless you have the diagram it will be difficult to get.
GE likes to keep all tech info a secret but you may get lucky on the net by searching the model number.
You have 2 problems that happened at the same time so it will be something common to both the table motor and the magnetron or it's control probably something in the power supply but cannot say for sure without a wiring diagram.
Microwave fuse blows out frequently (Microwave Repair)
by Guest 6/15/2024 4:55:42 AM(UTC)
LG LMV1680ST Microwave Door Switches (Microwave Repair)
by ctalbert150 6/13/2024 7:19:37 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
How to pull microwave out of mw/oven combo (Oven Repair (including Ranges and Cooktops))
by cromking 5/6/2024 1:13:05 PM(UTC)
Microwave goes dead when hot (Microwave Repair)
by Guest 5/5/2024 8:05:15 AM(UTC)
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 5/2/2024 6:28:45 AM(UTC)
GE PT7800SHASS Combination Microwave / Oven - Key Panel SHORTED (Oven Repair (including Ranges and Cooktops))
by RCAppl 4/23/2024 7:59:18 AM(UTC)
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
by Guest 2/13/2024 11:22:12 AM(UTC)
Kenmore Pizza Oven Microwave (Microwave Repair)
by mwjkmail 2/3/2024 5:10:49 PM(UTC)
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Whirlpool Microwave Lower Bulb will not turn on (WMH31017HS08) (Microwave Repair)
by Axtell 1/2/2024 3:49:44 PM(UTC)
Kitchen aid electric wall microwave and oven (Microwave Repair)
by Guest 11/9/2023 8:15:09 AM(UTC)
Frigidaire Microwave PLMVZ169HCA (Microwave Repair)
by Guest 10/25/2023 11:02:01 AM(UTC)
