MarMc
#1 Posted : Wednesday, June 13, 2012 1:37:37 PM(UTC)
MarMc
Apparently, the igniter for the rear left burner no longer works. Is this something I can replace myself? Please advise with instructions on how to do it.
Thank you.
Simon / APP Team
#2 Posted : Wednesday, June 13, 2012 3:36:16 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
When you turn the knob does the other ignitors spark?
Simon.
MarMc
#3 Posted : Thursday, June 14, 2012 8:36:18 AM(UTC)
MarMc
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
Yes, everything else works fine.
Simon / APP Team
#4 Posted : Thursday, June 14, 2012 10:21:11 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
I probably should rephrase my question.
When you turn the burner knob "in question" are the rest of the ignitors spark?
If they do than the problem could be - bad ignitor, wire insulation, bad spark module.
You can find the bad one by switching the wires around at the spark module.
To get to the module take off the burner heads, remove screws holding the top and lift it.
Remember - to check the ignitors the top must be placed back and at least one screw installed in each burner.
The spark module Part number: 316135702
The left rear ignitor/burner Part number: 318306106
Here are the breakdown diagrams and Replacement parts for Frigidaire PLGS389ECJ GAS RANGE | AppliancePartsPros.com
Good luck. Post the results.
Simon.
