Btconn82
#1 Posted : 13 years ago
Btconn82
The main pump on my 13 month old dishwasher does not work. I ran through the troubleshooting cycle, and there was no error codes. During the step that the main pump was supposed to kick on, there was nothing. I removed the pump, checked it (it spins freely), checked all the electrical connections and retried. Still no luck. I checked for good contiuntiy to ground, and I also tested for power. The first time I checked for voltage at the motor I found like 6 volts. The two other times I checked I got 0 volts. I removed the door cover and inspected the wiring all the way up. I checked the two fuses in the power/control board and they were ok. I'm assuming that the power board is bad. Is there anything else I can check?
Thanks,
