Apparently, the igniter for the rear left burner no longer works. Is this something I can replace myself? Please advise with instructions on how to do it. Thank you.
Groups: APP Team
Hi.
When you turn the knob does the other ignitors spark?
Simon.
Simon. Yes, everything else works fine.
Groups: APP Team
Hi. I probably should rephrase my question. When you turn the burner knob "in question" are the rest of the ignitors spark? If they do than the problem could be - bad ignitor, wire insulation, bad spark module. You can find the bad one by switching the wires around at the spark module. To get to the module take off the burner heads, remove screws holding the top and lift it. Remember - to check the ignitors the top must be placed back and at least one screw installed in each burner. The spark module Part number: 316135702
