Hi Gene,
Sorry it took me so long to respond but when I moved out the fridge I noticed that I can't open the back panel. Is it possible that the temperature control could be on the fritz? Please advise.
In case you forgot (since I took so long to respond - sorry) the original problem with my fridge is that the freezer works fine but the fridge is warm (55-60F). I can feel cool air come in with the freezer door open but when I close it I can't feel any cool air in the fridge. I've tried playing with the controls by moving the fridge all the way to 8 or 9 (highest) and the freezer as well but that hasn't been helping so I moved them both back to 6. There is a little frost on the back panel of my freezer so I'm not sure if it's a defrost issue BUT when I opened the area where the temperature control is located I didn't see anything wrong with the defrost control (then again I'm not sure what I would be looking for).
Thanks in advance for all your help.
I was just hoping to avoid having to call the GE repairman in so any words of widsom would greatly be appreciated.
I meant the rear panel IN the freezer (#201 on the diagram), not on the back of the refrigerator. According to your description there is a problem with the air flow from the freezer into the fresh food compartment. I do not think it has something to do with the temperature control. Gene.
Thanks for the response! I'm taking it apart now. Will write back in a minute. What to do if the coils are frozen?
Definitely Ice buildup. What do you suggest?
Ice or snow? Where is it - on the coils or under the coils?
More like a hard snow on the coils. It's not really under the coils.. just frozen on it. I melted some off with a hair dryer and it melted quickly but it didn't clear up totally yet.
Thanks so much Gene! I'll look into replacing the defrost timer. You're an angel! I'll keep you posted! ;-)
Do not rush with the parts. Perform the troubleshooting first. The defrost timer is the last part I would think about.
OK - thanks again. I'll try the troubleshooting and let you know where I end up. ;-)
