last night i started a load of landry and when i woke up this moring the washer was still half way fill up with the dirty water in it . when u put it on spin all it does is hum a little but that it what can it be
Groups: APP Team
Hi. Take off the front panel and check if the drain pump is running. Check all the drain hoses and the sump. Most likely there is a clogged drain or pump. For further assistance provide complete model number.
Thank you. Post the results.
thanks for the advise i found the clogged hose thank you again
Groups: APP Team
