kaclark7
#1 Posted : 13 years ago
kaclark7
Hi - I need help in determining what parts to order to solve this problem. The washer ran fine for two loads, then during the third load several things went wrong. Noticed a strong odor of rubber, and saw that the machine was spinning slowly but still had a lot of water in it and water was leaking on the floor from the edges of the cabinet. It was almost done with the cycle and shut off. I pulled the front panel and saw water dripping out of the tub where the transmission shaft enters. I siphoned about 6 gallons out (to the bottom of the inside tub) and the dripping stopped. I lowered the drain hose to dump the rest of the water and it drained fine. I looked under and the belts still looked ok and it seems like the pump turns ok when I turn the motor pully. The inside of the cabinet has some signs of oil splatter that flung off of the transmission.
I assume I need the tub seal and the bearing, and belts just to be sure. Why didn't the water pump out? Do I need a pump or is it something else? Can water leak into the transmission or is it still OK (it has never made any bad noises). Where can I get the instructions on how to replace the seal on the tub?
Thank you for your assistance - Kurtis
wapanstore
#2 Posted : 13 years ago
wapanstore
What could be causing my Maytag washer to leak water?
Laser pointer
applianceman
#3 Posted : 13 years ago
applianceman
This page should help
Maytag Tub Seal Replacement
Maytag washer leaking (Washer Repair)
by kpks26 11 years ago
Maytag Washer Leaking (Washer Repair)
by scottlassy 12 years ago
Maytag Washer Leaking Water into Tub (Washer Repair)
by mightypasta 13 years ago
maytag washer leaking and overflowing (Washer Repair)
by bennettelliott 15 years ago
maytag washer leaking (Washer Repair)
by mailmandennis 15 years ago
Maytag washer leaking from bottom (Washer Repair)
by Famof5 15 years ago
Maytag washer leaking, Seems to come from Pump (Washer Repair)
by mikou 15 years ago
Maytag washer leaking only on delicate cycle (Washer Repair)
by bsly58 16 years ago
