kdavis93
#1 Posted : 13 years ago
kdavis93
Washer stops during wash cycle and will not start. Sometimes if you wiggle the timer knob it will restart and run for a few minutes and stop again. The timer does not seem to work in any cycle. After several turns of the knob around the dial it will sometimes start again and will usually go through the remainder of the wash cycle once the timer is below the 6 minute mark on the normal wash cycle. Is this probably a bad timer?
sidfink43
#2 Posted : 13 years ago
sidfink43
It sounds very much like the timer, I would replace it and see if that fixes your problem.
Whirlpool washer timer problem (Washer Repair)
by cgaump 13 years ago
Whirlpool washer timer replacement (Washer Repair)
by kurtvance 13 years ago
Whirlpool washer timer function (Washer Repair)
by Ronc11 14 years ago
whirlpool washer timer stops during wash (Washer Repair)
by terryballou 15 years ago
Whirlpool Washer Timer Issue (Washer Repair)
by bdrendel 15 years ago
whirlpool washer timer (Washer Repair)
by steve masters 18 years ago
