My washer would not advance on any setting. I replaced the timer with new unit same part number. It clicks like it is advancing but does not advance. Am I missing something? I just need some help. Thanks:confused:
Sounds like a faulty timer to me. Was the replacement timer purchased new or what it a used timer?
New, same brand, same number. It does click like it is advancing and looking at it from behind the main cam is turning.
The timer cam seems to turn sometimes. If it fails after water fillup, you might have a bad water level switch.
