9 Pages<1234>»
#11 Posted : Friday, December 23, 2011 3:47:14 PM(UTC)
Make sure the condenser coils on the back are clean. Wait at least 12 hours and recheck the temperatures in both compartments. It's better to measure it, using a refrigerator thermometer.
ws6s
#12 Posted : Friday, December 23, 2011 3:54:38 PM(UTC)
ws6s
ok gene i will pull it out and remove the cover and vaccum over the coils.
i will let you know,thanks todd.
ws6s
#13 Posted : Saturday, December 24, 2011 8:28:39 AM(UTC)
ws6s
ok gene still at around 10 degrees and the freezer fan continues to run.:confused:
ws6s
#14 Posted : Saturday, December 24, 2011 4:52:15 PM(UTC)
ws6s
as of now it is at 15 degrees and rising.
#15 Posted : Saturday, December 24, 2011 5:15:26 PM(UTC)
Remove the rear panel in the freezer and check how the evaporator coils are covered with snow. If the coils are clean while the compressor is running, then there is a problem with the sealed system. It can be low on Freon. You have to call a pro to check the pressure in the sealed system.
ws6s
#16 Posted : Monday, December 26, 2011 12:43:56 PM(UTC)
ws6s
ok gene i finally pulled the panel off and it is all covered with snow.freezer temperature reads at 15 degrees at thermostat and around 30 from guage.heres a picture of the evaporator.
thanks todd
ws6s
#17 Posted : Monday, December 26, 2011 12:50:41 PM(UTC)
ws6s
UserPostedImage
#18 Posted : Monday, December 26, 2011 1:47:00 PM(UTC)
Check for continuity the defrost heater and overtemperature thermostat (#230 & #240 on the diagram) while they are cold. Post the results.
ws6s
#19 Posted : Monday, December 26, 2011 3:34:40 PM(UTC)
ws6s
gene the link to the diagram is no good can you please send it to me again.also the freezer is now at 21 degrees and holding.why didnt i have a problem b4 i replaced the motherboard with the freezer ? todd
#20 Posted : Monday, December 26, 2011 3:48:09 PM(UTC)
It's fixed. Sorry, my bad.
Guest (11)
9 Pages<1234>»
