3 Pages123>
gmsnowball
#1 Posted : Monday, December 19, 2011 12:37:43 PM(UTC)
gmsnowball
Kenmore Elite model 106 54602300 just stopped getting cold. Lost all the meat in the frezzer and the fridge side is only cool. Panel shows the unit to be working and cpmpressor appears to working. Could starter relay be bad or what? Happened all of a sudden.
#2 Posted : Monday, December 19, 2011 1:41:16 PM(UTC)
How hot is the compressor on touch?
Did you clean the condenser coils?
Do the both fans (next to the compressor and inside the freezer) work?
Remove the rear panel inside the freezer and check how the evaporator coils are covered with frost.
gmsnowball
#3 Posted : Monday, December 19, 2011 1:55:03 PM(UTC)
gmsnowball
Thanks, I will give it a shot.
gmsnowball
#4 Posted : Monday, December 19, 2011 2:24:11 PM(UTC)
gmsnowball
Panel is off and fan is running but there is no frost on coils. I checked the lower grill, on the bottom, it had some lint but not too much. Compressor appears to not be working, could it be a start up relay?
#5 Posted : Monday, December 19, 2011 4:14:16 PM(UTC)
Did you check the fan next to the compressor?
gmsnowball
#6 Posted : Monday, December 19, 2011 5:10:33 PM(UTC)
gmsnowball
No, is that on the back side of the fridge? Somewhat mechanically inclined but this is my first problem with a refrigerator.
#7 Posted : Monday, December 19, 2011 5:22:18 PM(UTC)
Yes, it is on the back. How did you determine that the compressor is not working without seeing it?
gmsnowball
#8 Posted : Monday, December 19, 2011 6:09:35 PM(UTC)
gmsnowball
Probably shouldn't assume, for obvious reasons, but thought it would be the compressor or maybe the start relay. It was working well and just quit all of a sudden. Is this something I can tackle myself or should I bring in an expert?
gmsnowball
#9 Posted : Tuesday, December 20, 2011 11:00:02 AM(UTC)
gmsnowball
Any ideas on what to do next
#10 Posted : Tuesday, December 20, 2011 11:14:38 AM(UTC)
Did you check the fan motor on the back and the compressor?
Guest (5)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
Kenmore Elite Commercial#25344723100 (Refrigerator & Freezer Repair)
by Stubblefield 6/13/2024 5:47:53 PM(UTC)
Water leaking from Kenmore Elite 10657789700 (Refrigerator & Freezer Repair)
by Guest 6/8/2024 12:11:48 PM(UTC)
Kenmore Elite not always cooling (Refrigerator & Freezer Repair)
by rankell1111 4/23/2024 5:23:39 AM(UTC)
Canning on a kenmore elite c970 688925 (Oven Repair (including Ranges and Cooktops))
by Guest 4/17/2024 9:34:41 PM(UTC)
Kenmore Elite (796.2900) uE error and now making weird sounds on startup/rinse... (Washer Repair)
by PirateToast 4/17/2024 8:20:21 AM(UTC)
kenmore elite smartheat quietpak 9 control has no power (Dryer Repair)
by Guest 2/18/2024 10:39:22 PM(UTC)
Kenmore Elite F09 error code (Washer Repair)
by dieselgg 10/19/2023 4:01:12 PM(UTC)
Kenmore Elite Refridgerator 795.799773.903 (Refrigerator & Freezer Repair)
by Rick_Titus 10/7/2023 4:28:57 PM(UTC)
Kenmore Elite Refridgerator control panel not working (Refrigerator & Freezer Repair)
by Guest 10/3/2023 10:18:35 AM(UTC)
Ice build up under meat drawer of my Kenmore Elite??? (Refrigerator & Freezer Repair)
by Guest 7/9/2023 4:39:18 PM(UTC)
kenmore elite door dispenser (Refrigerator & Freezer Repair)
by dhunt1984 7/7/2023 8:28:38 AM(UTC)
Kenmore elite standing ice maker strange noise (Refrigerator & Freezer Repair)
by Twicklund 6/10/2023 9:39:17 AM(UTC)
Kenmore Elite 796.31512211 (Washer Repair)
by johneddnm 5/23/2023 5:49:24 PM(UTC)
Kenmore Elite Washer error codes (Washer Repair)
by Cenzo 3/23/2023 12:58:19 PM(UTC)
3 Pages123>
