Kenmore Elite model 106 54602300 just stopped getting cold. Lost all the meat in the frezzer and the fridge side is only cool. Panel shows the unit to be working and cpmpressor appears to working. Could starter relay be bad or what? Happened all of a sudden.
How hot is the compressor on touch?
Did you clean the condenser coils?
Do the both fans (next to the compressor and inside the freezer) work?
Remove the rear panel inside the freezer and check how the evaporator coils are covered with frost.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) How hot is the compressor on touch?
Gene. Thanks, I will give it a shot.
Panel is off and fan is running but there is no frost on coils. I checked the lower grill, on the bottom, it had some lint but not too much. Compressor appears to not be working, could it be a start up relay?
Did you check the fan next to the compressor?
No, is that on the back side of the fridge? Somewhat mechanically inclined but this is my first problem with a refrigerator.
Yes, it is on the back. How did you determine that the compressor is not working without seeing it?
Probably shouldn't assume, for obvious reasons, but thought it would be the compressor or maybe the start relay. It was working well and just quit all of a sudden. Is this something I can tackle myself or should I bring in an expert?
Originally Posted by: gmsnowball ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Probably shouldn't assume, for obvious reasons, but thought it would be the compressor or maybe the start relay. It was working well and just quit all of a sudden. Is this something I can tackle myself or should I bring in an expert? Any ideas on what to do next ?
Originally Posted by: gmsnowball ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Any ideas on what to do next ? Did you check the fan motor on the back and the compressor? Gene.
