207 Pages«<2728293031>»
#281 Posted : Saturday, February 14, 2009 6:06:15 PM(UTC)
At this time I would set the right temperature for both compartments and stop to play with them. Let it run for a longer time (days or weeks) and just watch it.
Dave Wire
#282 Posted : Sunday, February 15, 2009 6:52:27 PM(UTC)
Dave Wire
I have this same problem (refer side warm freezer OK) and determined it was the heater coil. My coils were frozen over and the temp switch and temp rely were good.My question is can this also cause the ice maker not to work? I just replaced the water valve and the ice maker is still not working. I just ordered an ice maker from you. Once I get the ice maker should I install both or do the heater coil first and wait?
Dave Wire
#283 Posted : Sunday, February 15, 2009 7:56:40 PM(UTC)
Dave,
If the temperature in the freezer is more than 15°F then the ice maker will never work properly. Otherwise the ice maker has to be replaced.
bdaz1
#284 Posted : Monday, February 16, 2009 4:50:35 AM(UTC)
bdaz1
OK Gene. I'll leave it alone, watch it and, will report back in a few days. Thanks much for your help!
Dave Wire
#285 Posted : Monday, February 16, 2009 10:17:28 AM(UTC)
Dave Wire
What's the best way to replace (and easiest) to replace the thermostat? Through the floor of the freezer or somewhere through the front? I can see it when I lift up the floor of the freezer but it seems hard to cut the wires doing at that way.
GE TNS22PRCBRBS
#286 Posted : Monday, February 16, 2009 10:32:10 AM(UTC)
Dave,
As I can see on the diagram you have to remove the freezer floor and the evaporator cover. Perhaps the mullion cover (#203) and the freezer door have to be removed too.
bdaz1
#287 Posted : Monday, February 23, 2009 7:40:40 AM(UTC)
bdaz1
Gene,
Here's the latest. It seems like the thermostat may be the culprit. I've noted that the freezer and frig can cool sufficiently (0F & 38F) but, it seems that the unit continues to run until it's too cold (-5F & 30F). Even a minor adjustment to the thermostat at this point will cause the unit temp to rise too far (20F & 45F). I also noticed that when adjusting the thermostat, it sometimes does not respond (start/stop the unit). If I lightly tap the thermostat control knob, the refrigerator will come on (or go off). Also, yesterday, I initiated a manual defrost cycle by turning the thermostat off for 15 seconds/on for 5 seconds (three times) and then leaving it off. I could hear the ADC board relay click and the ice melting in the freezer and water draining. I set the thermostat back to the "normal" setpoint and, after a few mintues, the refrigerator came back on and cooled. Your thoughts?
#288 Posted : Monday, February 23, 2009 10:47:14 AM(UTC)
Originally Posted by: bdaz1 Go to Quoted Post
...It seems like the thermostat may be the culprit...
Very likely.
bdaz1
#289 Posted : Friday, February 27, 2009 12:45:31 PM(UTC)
bdaz1
Thermostat was the problem. Swapped it out and now, at factory (midpoint) settings for freezer & refrigerator, the freezer maintains 0F and the refrig is 35F. Thanks for your help Gene. Great website!
#290 Posted : Friday, February 27, 2009 2:18:34 PM(UTC)
You are welcome. We are glad you were able to fix it.
