SteveO59
#1 Posted : 13 years ago
SteveO59
Cannot activate control panel. Have replace control board tested door switches, examined wiring and power. Control panel cycle controls will not light up. Heated Dry/Sanitize lights will light up. No other obvious problems found. Unit is less than two years old
ApplianceJunk
#2 Posted : 13 years ago
ApplianceJunk
I can't find any info on model MD8H949AWW1 are you sure that is the correct model number?
SteveO59
#3 Posted : 13 years ago
SteveO59
MDBH949AWW1
SteveO59
#4 Posted : 13 years ago
SteveO59
Mdbh949aww!
SteveO59
#5 Posted : 13 years ago
SteveO59
Mdbh949aww1
SteveO59
#6 Posted : 13 years ago
SteveO59
Mdbh949aww1
SteveO59
#7 Posted : 13 years ago
SteveO59
My original post about my dishwasher not running has never gotten any response for help. Can anyone help? I have replaced the control board, tested the door latch - could it be the control panel? :confused:
ApplianceJunk
#8 Posted : 13 years ago
ApplianceJunk
Hi,
How about the thermal fuse?
Here is the tech sheet for your dishwasher, maybe it will help.
I tried to upload it as a attachment, but it must be to large.
https://servicematters.c...heet%20-%20W10142800.pdf
Jose6394
#9 Posted : 13 years ago
Jose6394
Ihada similar issue with my kitchenAid dishwasher. The problem was a thermal (bi-metal) fuse. It looks like the diameter of a nickel with two tabs on it.
Whirlpool dishwasher will not run (GU1500XTLS2) (Dishwasher Repair)
by mindnmines 8 years ago
Whirlpool Quiet PArtner III Pot/Pan light on and dishwasher will not run (Dishwasher Repair)
by DJ Chaffers 9 years ago
by gerry d 11 years ago
Roper dishwasher will not run cycles (Dishwasher Repair)
by Lfrisk 11 years ago
GE dishwasher will not run (Dishwasher Repair)
by carlos_m 12 years ago
dishwasher will not run no sign of life (Dishwasher Repair)
by peter pirri 14 years ago
Dishwasher will not run (Dishwasher Repair)
by mdr6140 14 years ago
by tapcon 15 years ago
by DeaconJ 15 years ago
by schmidt17 16 years ago
by superior l & l 16 years ago
Dishwasher will not run through cycles (Washer Repair)
by Butters 16 years ago
by mudhen 17 years ago
by mikegm 17 years ago
