Cannot activate control panel. Have replace control board tested door switches, examined wiring and power. Control panel cycle controls will not light up. Heated Dry/Sanitize lights will light up. No other obvious problems found. Unit is less than two years old
I can't find any info on model MD8H949AWW1 are you sure that is the correct model number?
Originally Posted by: ApplianceJunk ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I can't find any info on model MD8H949AWW1 are you sure that is the correct model number? MDBH949AWW1
My original post about my dishwasher not running has never gotten any response for help. Can anyone help? I have replaced the control board, tested the door latch - could it be the control panel? :confused:
Ihada similar issue with my kitchenAid dishwasher. The problem was a thermal (bi-metal) fuse. It looks like the diameter of a nickel with two tabs on it.
