mikegm
#1 Posted : 17 years ago
mikegm
Never had a problem with dishwasher until now. Will not start. Has power. Worked fine the day before.
#2 Posted : 17 years ago
The first thing (assuming there is 120V at the power outlet and the plug is not loose) I would do is remove the bottom panel, open the terminal box (unplug the power cord first) and check for burned wires.
If there is nothing wrong, remove the inner door panel and the cover and check the door switches for continuity. Inspect all wires.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter -How to check coninuity with Ohmmeter
- The part number for the door switch assembly is AP403996
Here are the break down diagrams for the Maytag dishwasher Model DWC7400AAW
Whirlpool dishwasher will not run (GU1500XTLS2) (Dishwasher Repair)
by mindnmines 8 years ago
Whirlpool Quiet PArtner III Pot/Pan light on and dishwasher will not run (Dishwasher Repair)
by DJ Chaffers 9 years ago
by gerry d 11 years ago
Roper dishwasher will not run cycles (Dishwasher Repair)
by Lfrisk 11 years ago
GE dishwasher will not run (Dishwasher Repair)
by carlos_m 12 years ago
Dishwasher will not run (Dishwasher Repair)
by SteveO59 13 years ago
dishwasher will not run no sign of life (Dishwasher Repair)
by peter pirri 14 years ago
by mdr6140 14 years ago
by tapcon 15 years ago
by DeaconJ 15 years ago
by schmidt17 16 years ago
by superior l & l 16 years ago
Dishwasher will not run through cycles (Washer Repair)
by Butters 16 years ago
by mudhen 17 years ago
