John765
#1 Posted : Saturday, January 3, 2009 8:42:47 PM(UTC)
John765
Hi
I'm having a problem with my Olsen furnace, the pilot light will light and then go out and will keep doing this until I turn off the furnace at the main power shutoff. The burner will not light. I think its the gas valve but i'm not sure. Any help with this would be great
John
ernesto1959
#2 Posted : Tuesday, January 6, 2009 11:58:05 PM(UTC)
ernesto1959
if it hold it ...cicle on may be ok....if pilot keeps shuting off , is time to get new thermocouple.
SublimeMasterJW
#3 Posted : Friday, January 23, 2009 12:20:03 PM(UTC)
SublimeMasterJW
Probably a contaminated flame sensor. The brains of your furnace needs confirmation of ignition. If it fails to recieve a capcitance change in the sensor then it shuts down and continues to retry ignition. Check this out:
Central Gas Furnace Quickly shuts down ‎(SublimeMasterJW's Appliance Advice‎)
Gas valve short cycling? (Oven Repair (including Ranges and Cooktops))
by stubborn1 11/26/2023 11:37:44 AM(UTC)
Robert Shaw Fireplace Gas Valve - Sticks (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 11/15/2023 4:04:14 PM(UTC)
GAS VALVE OR IGNITOR? (Oven Repair (including Ranges and Cooktops))
by JAMES B HOOKS 11/25/2020 10:38:10 AM(UTC)
Maytag MGD9700SQ0 Won't Heat/Open Gas Valve (Dryer Repair)
by jpc315 11/9/2020 2:59:17 PM(UTC)
HELP! Whirlpool Dryer Gas Valve (Dryer Repair)
by Steve60 2/16/2020 10:35:30 AM(UTC)
Whirlpool Gas Range won't light: gas valve shuts off after 1 or 2 seconds (Oven Repair (including Ranges and Cooktops))
by Drew42TX 4/22/2019 8:23:07 AM(UTC)
Replacing dryer gas valve (Dryer Repair)
by T-Rex 3/1/2017 10:51:31 AM(UTC)
New Gas valve and Ignitor (Oven Repair (including Ranges and Cooktops))
by wellshii 12/4/2014 12:03:29 PM(UTC)
No power to flame sensor, gas valves, or ignitor (Dryer Repair)
by ms0674 8/9/2014 2:37:45 PM(UTC)
Changed gas valve and dryer still not working (Dryer Repair)
by Manaus 5/31/2014 11:30:53 AM(UTC)
How do I test gas valve coils? (Dryer Repair)
by Dmalone1949@gmail.com 12/15/2013 10:40:40 AM(UTC)
No power to ignitor or gas valves (Dryer Repair)
by dougL 11/5/2013 10:25:33 AM(UTC)
Access to Gas Valve - Maytag stackable (Dryer Repair)
by Defens 9/17/2013 1:23:39 PM(UTC)
Gas valve wire cap broke off (Oven Repair (including Ranges and Cooktops))
by repairnoob1 9/9/2013 8:34:40 AM(UTC)
Gas valve replacement? (Dryer Repair)
by denne20 8/26/2013 7:13:37 AM(UTC)
