frankla10
#1 Posted : Tuesday, January 20, 2009 2:35:36 PM(UTC)
frankla10
My KitchenAid Washer won't spin but will drain. When it goes into the spin cycle it has a loud clicking noise. I manually tried to spin the basket when it was running (using a screwdriver to press the safety button). I could spin the basket by hand but still had the same clicking noise and no auto-spin.
richappy
#2 Posted : Wednesday, January 21, 2009 2:56:03 AM(UTC)
richappy
If it clicks in agitate also, you have a busted tranny coupler AP3963893.
kayakcrzy
#3 Posted : Wednesday, January 21, 2009 4:47:07 AM(UTC)
kayakcrzy
How to Replace Whirlpool Washer Couplers Check out this website, it will give you a breakdown on how to take it apart, and install the coupler. Tom ApplianceEducator.com
frankla10
#4 Posted : Wednesday, January 21, 2009 8:42:57 AM(UTC)
frankla10
I tried it in Agitate mode and it is working in that mode but it still won't spin.
richappy
#5 Posted : Wednesday, January 21, 2009 2:01:08 PM(UTC)
richappy
Pull your agitator out and check for a bad drive block or a loose drive block nut.
frankla10
#6 Posted : Wednesday, January 21, 2009 2:57:47 PM(UTC)
frankla10
Are there instructions on how to get to the drive block anywhere? What do I look for? I did try it again and noticed that, while it DOES agitate, it seems quite a bit louder (the grinding/clicking sound similar to when the drum should spin).
frankla10
#7 Posted : Friday, January 23, 2009 4:50:29 PM(UTC)
frankla10
I did pull the agitator out but can't figure out how to determine whether the drive block is bad.
richappy
#8 Posted : Saturday, January 24, 2009 12:27:29 AM(UTC)
richappy
Look carefully at the drive block with the large nut on top. You can see the steel spin tube tabs sticking up. Are these tabs moving when you turn the spin basket. If so, you have a bad drive block. Continual running like this will wear out the spin tube and that job is a lot more expensive than replacing the drive block. You will need a special spanner wrench available on this parts site to fix this.
kitchenaid washer won't spin (Washer Repair)
by rdtjr1968 9/23/2012 2:54:36 PM(UTC)
Kitchenaid washer won't spin (Washer Repair)
by Fidsters 10/16/2010 4:40:37 PM(UTC)
Kitchenaid Washer won't spin/agitate (Washer Repair)
by sofasurfer 7/26/2009 7:05:34 PM(UTC)
by graciousaint 5/18/2009 5:38:16 AM(UTC)
Help! Kitchenaid washer won't spin or drain (Washer Repair)
by harleygurl 11/28/2008 3:54:39 PM(UTC)
KitchenAid washer won't spin (Washer Repair)
by Sherry 8/30/2007 5:57:43 AM(UTC)
