This should be easy for some one who has worked on this machine. It's a maytag commercial dryer and I cant see how to get the cabinet apart. Someone suggested I take off the coin holder and there was a nut . Well there was but it didnt seem to release the top. Any ideas. or where I might find a repair manual. I guessed at the age because it is in the apartment where I live. Thanks for your help.
Thanks for the breakdown. Would still appreciate knowing how to get it apart.
Try this: remove the screw on each side on the bottom of the front panel. Grab the front panel on the bottom and lift it up till about 45° to release it from the top fasteners. Open the diagrams and you'll see what to do next.
Thanks Gene, I will give it a try in the morning, If I tried it now I might get kicked out for waking some one up. thanks again, hope it works. VErn
I see why Gene is a senior expert. This was the awnser I needed. It worked like a charm. Now I just have to figure out what the noise is. Thanks again.
My problem was a bad blower wheel, it was out of round and loose on the shaft. Thanks for your help. Vern
You are welcome. We are glad you were able to fix it.
