vtrike
#1 Posted : 16 years ago
vtrike
This should be easy for some one who has worked on this machine. It's a maytag commercial dryer and I cant see how to get the cabinet apart. Someone suggested I take off the coin holder and there was a nut . Well there was but it didnt seem to release the top. Any ideas. or where I might find a repair manual. I guessed at the age because it is in the apartment where I live.
Thanks for your help.
libertyappl
#2 Posted : 16 years ago
libertyappl
here's a parts breakdown
Model MDE10CSACW
Nat
vtrike
#3 Posted : 16 years ago
vtrike
Thanks for the breakdown. Would still appreciate knowing how to get it apart.
#4 Posted : 16 years ago
Try this: remove the screw on each side on the bottom of the front panel. Grab the front panel on the bottom and lift it up till about 45° to release it from the top fasteners. Open the diagrams and you'll see what to do next.
vtrike
#5 Posted : 16 years ago
vtrike
Thanks Gene, I will give it a try in the morning, If I tried it now I might get kicked out for waking some one up.
thanks again, hope it works.
VErn
vtrike
#6 Posted : 16 years ago
vtrike
I see why Gene is a senior expert. This was the awnser I needed. It worked like a charm. Now I just have to figure out what the noise is.
Thanks again.
vtrike
#7 Posted : 16 years ago
vtrike
My problem was a bad blower wheel, it was out of round and loose on the shaft. Thanks for your help. Vern
#8 Posted : 16 years ago
You are welcome. We are glad you were able to fix it.
Whirlpool LDA7600W0 Cabinet Removal (Washer Repair)
by rudyrudy 12 years ago
Whirlpool cabinet removal (Washer Repair)
by scott1980 14 years ago
gE wASHER CABINET REMOVAL (Washer Repair)
by CAROLEANNE411 15 years ago
by rnhent12 16 years ago
by beadyiwoman 17 years ago
Cabinet removal (Washer Repair)
by jumbyway 18 years ago
