Jim Brizz
#1 Posted : Tuesday, December 30, 2008 5:35:44 PM(UTC)
Jim Brizz
When I turn the dial to start the cycle, the washer starts as it should, then the dial doesn't move and the washer just stays in that part of the cycle. In the repair tips section, it says that a defective timer or selector switch is uncommon.
TechnicianBrian
#2 Posted : Tuesday, December 30, 2008 6:32:29 PM(UTC)
TechnicianBrian
Hey Jim,
A defective timer is not very common, but if you move the timer to different points and it never moves, then the timer needs to be replaced. There are probably some bad contacts within the timer preventing the motor from getting power.
GE Diswasher Timer not moving !! (Dishwasher Repair)
by robin hood 7/31/2012 4:40:40 PM(UTC)
no gas, timer not moving (Dryer Repair)
by PPDCOP 3/5/2012 5:14:01 PM(UTC)
Timer not moving... (Washer Repair)
by Jeff Kucic 12/30/2011 11:52:15 AM(UTC)
Dryer Timer Not Moving (Dryer Repair)
by wimmerrw 10/13/2011 9:46:56 AM(UTC)
Kenmore Dryer - Timer not moving with No heat and dryer does not shut off (Dryer Repair)
by poslow 11/21/2010 4:18:55 PM(UTC)
whirlpool dryer timer not moving (Dryer Repair)
by jonathan8 3/26/2009 6:00:58 AM(UTC)
Timer not moving but is working (Washer Repair)
by Cannonauto 2/8/2008 8:15:49 AM(UTC)
electric dryer won't heat and timer not moving (Dryer Repair)
by chefbeav 12/27/2007 10:58:40 AM(UTC)
