Jim Brizz
#1 Posted : 16 years ago
Jim Brizz
When I turn the dial to start the cycle, the washer starts as it should, then the dial doesn't move and the washer just stays in that part of the cycle. In the repair tips section, it says that a defective timer or selector switch is uncommon.
TechnicianBrian
#2 Posted : 16 years ago
TechnicianBrian
Hey Jim,
A defective timer is not very common, but if you move the timer to different points and it never moves, then the timer needs to be replaced. There are probably some bad contacts within the timer preventing the motor from getting power.
GE Diswasher Timer not moving !! (Dishwasher Repair)
by robin hood 13 years ago
no gas, timer not moving (Dryer Repair)
by PPDCOP 13 years ago
Timer not moving... (Washer Repair)
by Jeff Kucic 13 years ago
Dryer Timer Not Moving (Dryer Repair)
by wimmerrw 13 years ago
Kenmore Dryer - Timer not moving with No heat and dryer does not shut off (Dryer Repair)
by poslow 14 years ago
whirlpool dryer timer not moving (Dryer Repair)
by jonathan8 16 years ago
Timer not moving but is working (Washer Repair)
by Cannonauto 17 years ago
electric dryer won't heat and timer not moving (Dryer Repair)
by chefbeav 17 years ago
