Rank:: Member
every 3 or 4 months the fridge and the freezer stop cooling. I have to turn it off for a while then turn it back on to get it going again. Any suggestions. Anybody else have this problem?
Does it build up with frost on the back of the freezer? Can you give me more details then that. Tom ApplianceEducator.com
Rank:: Member
I haven't noticed any build up. It just stops cooling and freezing on each side.
If the whole unit shuts down, and you here no noise, I would suspect the thermostat or the defrost timer. If you hear it running, and it is not cooling, I would suspect the overload and relay on the compressor. You need to establish when the refrigerator is not cooling, if the refrigerator is running or not. Tom ApplianceEducator.com
Rank:: Member
thank you. I will keep an eye on it next time it happens.
