terrymi
#1 Posted : Sunday, November 30, 2008 2:35:45 PM(UTC)
terrymi
I have a magic chef Refrigerator side by side Every 14 mins it kicks on and 7 mins of run time it kicks off. I have replaced the thermostat twice thinking that was the problem but like (clockwork ) it keeps on all three thermostats the same thing. The door seals are good shape with no leaks the fans are find with no dirt built up.Keeps everything cold . Is there a relay?
Drags1998
#2 Posted : Sunday, November 30, 2008 3:00:59 PM(UTC)
Drags1998
As a Tech.I'm a little confused. Temps are fine!! It runs Fine, You replaced the same part (which rarely fail,2 times) and still it runs the same. Is it the 50% run time that bothers you? How full is the unit? :)
terrymi
#3 Posted : Monday, December 1, 2008 3:41:02 AM(UTC)
terrymi
What bothers me is how often it comes off and on...,no there is not much food.I replace the therm thinking it was bad but it wasn't.
AaronG
#4 Posted : Monday, December 1, 2008 3:47:20 AM(UTC)
AaronG
Sounds like it is fine to me also
#5 Posted : Monday, December 1, 2008 4:08:15 AM(UTC)
Here is the parts breakdown
Model Search
Check that your condenser fan is running,
Check the condenser coils and fan blade to make sure they are clean.
Looks like you have a jellyroll condenser coil, these are a pain to clean.
If it is dirty down there the easiest way to clean is with compressed air or a leaf blower. Best to do this outside but getting it outside is again a pain.
This is how I do mine.
Remove the rear access panel and front kick plate
Remove the drip tray
Roll the unit to an open door
Do it on a day that the wind is not directed at the door or it will just blow the dust back into the house.
Blow the unit clean from the back to the front, most of the dust should end up outside.
Cafe fridge keeps warming up. Help! (Refrigerator & Freezer Repair)
by Guest 6/28/2024 8:33:23 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Nursing Paper Review SOS: Help a Peer Out! (General Talk)
by Guest 6/19/2024 3:00:02 AM(UTC)
Diagnostic Code Help (I screwed something up) (Refrigerator & Freezer Repair)
by megarms 5/20/2024 7:30:54 AM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 5/2/2024 6:28:45 AM(UTC)
Need Help Identifying Part Manufacturer (Oven Repair (including Ranges and Cooktops))
by anonymous24 5/1/2024 3:25:51 PM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
by Orlando123 4/20/2024 10:55:35 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 3/14/2024 2:37:10 PM(UTC)
Help finding the right screws to secure the top panel. (Washer Repair)
by mikkel3906z 2/20/2024 12:30:41 AM(UTC)
Dishwasher electrical help (Dishwasher Repair)
by Guest 1/11/2024 4:35:37 PM(UTC)
Washer help please maytag (Washer Repair)
by Guest 12/13/2023 4:45:08 AM(UTC)
