AppliancePartsPros.com
Appliance Repair Help
Washer Repair
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal
This older machine has served me very well (knock on wood!) owned since new (25+ yrs) just started leaking out of what looks like weeping holes in the tub seal.
Removed boot seal--all looks to be in decent shape--any ideas what I should be replacing.
Pretty steady drip during use.
Any help would be appreciated!
I'm not sure how these things seal out the water--is that teflon ring (hard surface to hard surface) supposed to prevent water in tub from seeping through? Seems like a tall order for hard surface to hard surface to keep water out--can someone pls explain how this works?
Washer Repair
