murielh
#1 Posted : Sunday, May 22, 2011 9:25:08 AM(UTC)
murielh
Machine's sensor fails to stop at water FILL and water RINSE cycles.
Have to manually move dial. All other cycles work normal.
sidfink43
#2 Posted : Monday, May 23, 2011 2:51:34 PM(UTC)
sidfink43
Celan out the tube going from the water level switch to the tub. Watch it operate with the cabinet off. Water should not enter the tube. You can also pull the tube off at the tub level, stick your finger on the tub part to keep water from coming out and blow into the tube. If it does not stop water entering the water level switch is bad.
If all this does not help, try changing out the water level switch.
murielh
#3 Posted : Saturday, May 28, 2011 6:14:06 AM(UTC)
murielh
Thanks to Sidfink43 for directing me to the water level switch. The clear tubing/hose that connects to the water level switch had fallen off. (most likely happened when moving from house to house)
sidfink43
#4 Posted : Saturday, May 28, 2011 9:45:13 AM(UTC)
sidfink43
Well good, glad you founhd the problem and did not have to have a service call.
kitchenaid washer kaws800gq1 (Washer Repair)
by maagk 7/10/2020 5:47:30 AM(UTC)
Kitchenaid washer does everything but spin (Washer Repair)
by donohu40 10/27/2016 7:34:05 AM(UTC)
KitchenAid washer stopped spinning (Washer Repair)
by Punisher Bass 7/10/2015 4:30:16 PM(UTC)
need helpplease with trouble shooting kitchenaid washer (Washer Repair)
by lmormsby 5/14/2014 2:55:31 PM(UTC)
Older kitchenaid washer that worked fine and then? (Washer Repair)
by yepyepdude 1/29/2014 7:30:32 AM(UTC)
Kitchenaid washer pulling my hair out! (Washer Repair)
by DANShandy 7/29/2013 4:28:39 AM(UTC)
KitchenAid Washer Weird Issue -Electrical? (Washer Repair)
by zee652 4/2/2013 8:17:05 AM(UTC)
KitchenAid Washer won't drain or spin (Washer Repair)
by MSUMOM 3/14/2013 7:25:53 PM(UTC)
KitchenAid Washer (Washer Repair)
by ellmer 9/25/2012 1:25:15 PM(UTC)
kitchenaid washer won't spin (Washer Repair)
by rdtjr1968 9/23/2012 2:54:36 PM(UTC)
a Kitchenaid washer (Washer Repair)
by wapanstore 2/20/2012 8:15:00 PM(UTC)
kitchenaid washer throwing fault codes (Washer Repair)
by buldog9 1/18/2012 11:45:18 AM(UTC)
by carrisal 10/13/2011 3:22:01 PM(UTC)
by carrisal 9/30/2011 2:45:01 PM(UTC)
Kitchenaid washer with very slow agitation (Washer Repair)
by brewer89 3/17/2011 10:19:40 AM(UTC)
