Please furnish step by step instructions on removing and replacing the turntable motor and adapter that sits under the glass turntable plate...
Please also furnish your item/part numbers for both the turntable motor and the three sided "D" shaft adapter
Turntable is lurching and making a grinding noise but is still turning
Thanks much in advance
Originally Posted by: frank n texas ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Please furnish step by step instructions on removing and replacing the turntable motor and adapter that sits under the glass turntable plate...
Thanks much in advance Frank, Here are the part numbers you requested, Part number: AP2632784
Part number: AP3791385
And here's a general repalcement procedure, (there's not much information) Disconnect the power cord, or power to the unit. Remove the turntable plate, and carriage(if equipped) and drive coupling from cavity. Turntable Motor Removal Remove screws from the bottom of the microwave oven cabinet and remove the bottom plate. Remove the screw, then rotate the motor CCW 1/ 8 turn. Remove the turntable motor. Disconnect 2 wires from the motor. Reverse procedure and test unit. We hope this helps, Good Luck, :) :) :)
Thanks ever so much for all the info Joe....Really appreciate it...I did try searching the web for the info before bothering you guys....Not much luck...
Have a good day...
frank n texas
Originally Posted by: frank n texas ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks ever so much for all the info Joe....Really appreciate it...I did try searching the web for the info before bothering you guys....Not much luck...
Have a good day...
frank n texas Frank, I had the same problem, we did the best we could, the information should be able to get you through the repair. It's always a pleasure to assist our customers. You have a good day as well, and thanks for contacting Appliance Parts Pros Repair Forum. :) :) :)
