frank n texas
#1 Posted : Friday, March 25, 2011 8:02:29 AM(UTC)
frank n texas
Please furnish step by step instructions on removing and replacing the turntable motor and adapter that sits under the glass turntable plate...
Please also furnish your item/part numbers for both the turntable motor and the three sided "D" shaft adapter
Turntable is lurching and making a grinding noise but is still turning
Thanks much in advance
Joe / APP Team
#2 Posted : Friday, March 25, 2011 8:49:14 AM(UTC)
Joe / APP Team
Frank,
Here are the part numbers you requested,
Part number: AP2632784
Part number: AP3791385
And here's a general repalcement procedure,
(there's not much information)
Disconnect the power cord, or power to the unit.
Remove the turntable plate, and carriage(if equipped) and drive coupling from cavity.
Turntable Motor Removal
Remove screws from the bottom of the
microwave oven cabinet and remove the bottom
plate.
Remove the screw, then rotate the motor CCW 1/
8 turn. Remove the turntable motor. Disconnect 2
wires from the motor.
Reverse procedure and test unit.
We hope this helps,
Good Luck,
frank n texas
#3 Posted : Friday, March 25, 2011 9:02:52 AM(UTC)
frank n texas
Thanks ever so much for all the info Joe....Really appreciate it...I did try searching the web for the info before bothering you guys....Not much luck...
Have a good day...
frank n texas
Joe / APP Team
#4 Posted : Friday, March 25, 2011 2:08:57 PM(UTC)
Joe / APP Team
Have a good day...
frank n texas
Frank,
I had the same problem, we did the best we could, the information should be able to get you through the repair.
It's always a pleasure to assist our customers.
You have a good day as well, and thanks for contacting Appliance Parts Pros Repair Forum.
How to test turntable motor? (Microwave Repair)
by himberd 3/18/2014 7:37:48 AM(UTC)
Microwave Turntable Motor Question (Microwave Repair)
by tomjonesrocks 3/2/2012 9:06:11 AM(UTC)
Turntable Motor (drive vs. stirrer) (Microwave Repair)
by PoggiPJ 6/28/2009 6:28:26 PM(UTC)
GE microwave turntable motor (Microwave Repair)
by verndewitt 10/20/2008 12:03:49 PM(UTC)
How do I connect wires to turntable motor? (Microwave Repair)
by ltml82 2/20/2008 3:16:48 PM(UTC)
Buying the right microwave turntable motor (Microwave Repair)
by rcollison 11/16/2007 7:44:37 AM(UTC)
