Requesting troubleshooting list for dryer not wanting to heat at all.
Chk power to unit, make sure you are getting 240, if so go to elemt, chk with multi meter to make sure u have a closed circuit then chk the other 2 fuses on your htr tube, they should also be closed, if so go the thermal fuse make sure it is closed. hope this helps.
