bkenner
#1 Posted : Sunday, March 23, 2014 5:42:55 PM(UTC)
bkenner
This is a unit that you access the heating element from the front. Replaced it today and still blowing cold air. What should I do next.
#2 Posted : Monday, March 24, 2014 9:26:40 AM(UTC)
Your model number seems incomplete.
Kenmore's are usually 3 digits, a period and then another 8 digits.
bkenner
#3 Posted : Monday, March 24, 2014 9:31:59 AM(UTC)
bkenner
Serial No. MD1602420
Model 96591400
#4 Posted : Monday, March 24, 2014 10:03:38 AM(UTC)
Sorry still cannot find anything using that model number.
Perhaps go to the Sears parts site and look up
11096591400
Is that your unit?
If it is I cannot find a wiring diagram, do you have it?
If not have you checked in the control console ofter they store it in there.
Have you checked the power?
The heating element requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
Be careful as 240 volts is lethal !!!
bkenner
#5 Posted : Monday, March 24, 2014 10:17:00 AM(UTC)
bkenner
This is in a brand new apartment complex. I have tried flipping the breakers a few times but don't think that is the problem. I had to replace the plug on the dryer as well because it was the old style.
Do you think I need to move my ground maybe.
#6 Posted : Tuesday, March 25, 2014 1:20:35 AM(UTC)
Was the re-wire for a 3 wire to a 4 wire power cord?
If yes then the ground strap that connects the center connector (white) to the machine frame has to be disconnected. Then the white from the new power cord goes to the center connector and the green from the new cord goes to the machine frame.
The red and black stay the same.
The ground should not effect the uit heating as ground/Neutral is not part of the heating element's circuit.
You need a meter and actually measure the voltage, otherwise you could end up tearing the unit apart just to find out after wasting a lot of time that it was a power problem.
Also if the power is OK the meter is a useful tool when troubleshooting parts is the heater circuit.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Kenmore dryer not heating (Dryer Repair)
by jpdkrty 8/13/2016 3:50:00 PM(UTC)
Kenmore dryer not heating properly (Dryer Repair)
by yyzt4e 7/8/2015 4:58:45 PM(UTC)
Kenmore Dryer Not Heating After We Did Changed the Rear Drum Felt Seal (Dryer Repair)
by kytre 6/2/2015 7:25:49 PM(UTC)
by Drichie 5/21/2013 3:29:30 PM(UTC)
Kenmore dryer not heating - next steps? (Dryer Repair)
by bangelus 12/6/2012 5:59:36 AM(UTC)
by murphy7513 7/4/2012 8:17:34 PM(UTC)
Kenmore Dryer not heating (Dryer Repair)
by PIO_ACA_CMY 1/5/2012 3:23:10 PM(UTC)
kenmore dryer not heating (Dryer Repair)
by bwoltanski 12/27/2011 9:01:29 AM(UTC)
by Dando 6/18/2011 12:45:41 PM(UTC)
by TexFordD 3/20/2011 10:15:14 AM(UTC)
by JaxMax 3/14/2011 9:11:16 AM(UTC)
by MBKENMORE 9/8/2010 10:00:42 AM(UTC)
by RepDry 9/23/2009 4:48:25 PM(UTC)
by lego1231 9/21/2009 8:18:43 AM(UTC)
Electric Kenmore Dryer not heating (Dryer Repair)
by morenojx 9/2/2009 7:32:58 AM(UTC)
