PIO_ACA_CMY
#1 Posted : Thursday, January 5, 2012 3:23:10 PM(UTC)
PIO_ACA_CMY
I have a brand new dryer that is not heating. The drum rotates and the lights for the cooling cycle is on but the heat light is blinking and the dryer never heats up.
Samsonmind
#2 Posted : Thursday, January 5, 2012 8:19:59 PM(UTC)
Samsonmind
You have been a member since:: 1/5/2012(UTC)
My Dryer Will Not Heat What Is The Problem Do You Know?
#3 Posted : Friday, January 6, 2012 4:47:50 AM(UTC)
[COLOR="Blue"]PIO_ACA_CMY [/COLOR]
Your model number is missing the last 4 digits.
I am going to assume that it is an electric dryer.
First thing to check is the power to the unit.
The board and motor use half the line but the heating element needs the full 240 volts.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
Since it is new I would just check for the power at the receptacle if it is ggod then put in a service call.
If the unit did not come with a power cord then also check for power at the terminal strip in the unit as you may have installed a bad power cord. Then if that is good put in a service call.
I advise a service call because if you open the unit up they could void your warranty. Also if you mess something up which is always a possibility, it will not be covered by warranty. And lastly it could be an expensive part that needs replacing.
Kenmore dryer not heating (Dryer Repair)
by jpdkrty 8/13/2016 3:50:00 PM(UTC)
Kenmore dryer not heating properly (Dryer Repair)
by yyzt4e 7/8/2015 4:58:45 PM(UTC)
Kenmore Dryer Not Heating After We Did Changed the Rear Drum Felt Seal (Dryer Repair)
by kytre 6/2/2015 7:25:49 PM(UTC)
Kenmore Dryer not heating (Dryer Repair)
by bkenner 3/23/2014 5:42:55 PM(UTC)
by Drichie 5/21/2013 3:29:30 PM(UTC)
Kenmore dryer not heating - next steps? (Dryer Repair)
by bangelus 12/6/2012 5:59:36 AM(UTC)
by murphy7513 7/4/2012 8:17:34 PM(UTC)
kenmore dryer not heating (Dryer Repair)
by bwoltanski 12/27/2011 9:01:29 AM(UTC)
by Dando 6/18/2011 12:45:41 PM(UTC)
by TexFordD 3/20/2011 10:15:14 AM(UTC)
by JaxMax 3/14/2011 9:11:16 AM(UTC)
by MBKENMORE 9/8/2010 10:00:42 AM(UTC)
by RepDry 9/23/2009 4:48:25 PM(UTC)
by lego1231 9/21/2009 8:18:43 AM(UTC)
Electric Kenmore Dryer not heating (Dryer Repair)
by morenojx 9/2/2009 7:32:58 AM(UTC)
